Dato/klokkeslett: Ons 28. Okt 2026 23:52
Opprett et nytt emne Svar på emnet  [ 112 innlegg ]  Gå til side Forrige  1, 2, 3, 4, 5, 6 ... 8  Neste
InnleggSkrevet: Fre 16. Des 2011 13:07
Registrert: Fre 25. Nov 2011 21:29
Yes I am back from Stavanger trip ;-) Has take down Poland next 2 cars from Norway to fix. If the owners agree to put pictures on internet then I will put work progress here ;-)
Back to topic...
Here are next pictures, why You have to sand Your car. Sometime it is not visible, but after sanding You will see next places to fix. Sand while hitting metal in some places make holes (where metal was thin like paper) - If You do not fix these areas then You will get bubbles soon ;-) I was thinking keep deck lid filler panel, but after sanding - it shows that is thin like paper in some places (black holes) so it need to be replaced too.
The same at roof - we have to fix it there ;-) not so easy job on this car... ;-)
example1.jpg [ 54.53 KiB | Vist 5219 ganger ]
example2.jpg [ 50.31 KiB | Vist 5219 ganger ]
InnleggSkrevet: Lør 17. Des 2011 18:05
Another week of cutting....
This cutting work do not have end.... where You touch - there You have to cut.... what a nightmare. #-o
I have decided to keep oryginal panel with stamped numbers, and oryginal shock towers, but it will be more work to kep it than cut completty front clip, and build it from begining. :D
example1.jpg [ 74.61 KiB | Vist 5132 ganger ]
example2.jpg [ 96.85 KiB | Vist 5132 ganger ]
InnleggSkrevet: Tor 22. Des 2011 22:12
Good tip what I get from Geir, is to use a welding primer when and where possible. So we spray every bare metal with primer. Later some wax will be sprayed here....
weld1.jpg [ 77.62 KiB | Vist 5047 ganger ]
InnleggSkrevet: Tor 22. Des 2011 22:19
Hello.... is there someone reading this ;-) ??? nobody make a comments? :lol:
We start welding this week.... just step by step...
weld2.jpg [ 82.67 KiB | Vist 5043 ganger ]
weld3.jpg [ 75.94 KiB | Vist 5043 ganger ]
InnleggSkrevet: Tor 22. Des 2011 22:25
In this car rear framerails and torque boxes are in perfect condition. We just weld around factory mounting, and make it little bit stronger in a places, where car will be soon pushed by rear end ;-)
weld4.jpg [ 69.29 KiB | Vist 5040 ganger ]
InnleggSkrevet: Tor 22. Des 2011 22:43
1103 is reading this ;) most only look at pictures :D
What is his plan whit the car, make orginal mustang or some cracy norwegian twist?
InnleggSkrevet: Tor 22. Des 2011 23:12
Bosted: eidsvoll
good work.. more pictures.. i must say you are crazy when you start fix this car.. but im sure it will be good..
bedre seint enn aldri...
78 chevrolet camaro
66 chevrolet sportvan delux
InnleggSkrevet: Lør 24. Des 2011 13:30
He is going to keep it factory, as much as possible. Next Mustang project, waiting in queue, will be some crazy Norwegian Eleanor, with SVT engine (The strongest factory Cobra engine).
InnleggSkrevet: Lør 24. Des 2011 13:35
More pictures..... trunk floor almost finished.....
weld5.jpg [ 87.53 KiB | Vist 4940 ganger ]
weld6.jpg [ 89.6 KiB | Vist 4940 ganger ]
InnleggSkrevet: Tir 27. Des 2011 13:56
Soon it will be like this ;-) now only test feeting. I has bought the best, made by Dynacorn panels, but it does not feet like always.... lot of hummer work to do ;-)
test_feeting.jpg [ 57.97 KiB | Vist 4850 ganger ]
InnleggSkrevet: Fre 30. Des 2011 10:14
Back of a car... welding almost finished. We should finish back of this car this year ;-) Happy new 2012 year for all of You crazy american cars lovers ;-) I wish You more projects, more nice Mustangs on roads...
rear3.jpg [ 63.69 KiB | Vist 4716 ganger ]
rear4.jpg [ 51.47 KiB | Vist 4716 ganger ]
rear2.jpg [ 65.42 KiB | Vist 4716 ganger ]
rear1.jpg [ 53.34 KiB | Vist 4716 ganger ]
InnleggSkrevet: Fre 30. Des 2011 16:32
arent you afraid that the whole car will twist when you remove so much of the bodywork?
InnleggSkrevet: Fre 30. Des 2011 19:44
Hello, no I am not affraid. When You build back of a Mustang there it is easy job, when do not replacing framerails. The car is sitting on stands, holding it by rockers. Before ewery small weld all is checking and measure (angles and diagonals) after fiew (holding) welding points it is checking with measure again... and at the end it have to be perfect. We have also the same body waiting for works, and do compare in important points too.
The biggest worry about twisting I have at the front. We will replace complette frame rails, radiator support, etc.... that's why we weld fiew crossing struts at the front, to keep factory positions. At the front it will be more measuring and levelling than welding ;-)
InnleggSkrevet: Fre 30. Des 2011 22:51
Measure three times, weld once... :-)
InnleggSkrevet: Fre 30. Des 2011 23:53
You frankly dont have a clue do you.
