Dato/klokkeslett: Tir 25. Aug 2026 00:35
InnleggSkrevet: Tor 27. Apr 2006 17:37
Registrert: Søn 19. Feb 2006 21:28
Noen som vet?
 Innleggets emne: Forskjell
InnleggSkrevet: Tor 27. Apr 2006 20:47
Bosted: Iambroken
Sjekk ut denne linken ;
http://www.norskmustangclub.no/phpBB2/v ... php?t=1686
InnleggSkrevet: Fre 28. Apr 2006 07:45
Site Boss
Site Boss
Bosted: Hokksund
351 Cleveland og 351Windsor er 2 helt forskjellige motorer. Her er en forklaring på forskjellene, som jeg fant på nettet.
(from John Dettori. jdettori@bear.com)
Now a 351 Windsor is really a slightly enlarged 289/302, as it's name implies it comes from Fords "Windsor" engine family (a.k.a. the 90-degree V engine family). The thin-wall cast SMALL BLOCK accepts regular sized spark plugs, uses a timing chain in the block, routes water through the intake manifold, features thin main-bearing caps, a very good oiling system, and uses the same heads for 2V & 4V versions. The heads are are small, utilizing in-line valves with relatively small ports. The valves are 1.78" intake and 1.54" exhaust, i.e. the same size as a 289/302. The valve covers are straight (front to rear), attached by 5 bolts, and when removed you can see 351 cast in the lifter valley. The small side-by side (in-line) valves are the dead give-away.
The 351 Cleveland, on the other hand, belongs to Ford's 335 engine family. This thin-wall cast BIG SMALL BLOCK uses the smaller 14mm spark plugs, has a separate front cover (bolted to the block) housing the timing chain and routing water - so that water does not go through the intake manifold, features beefy main caps (wide enough to drill for 4-bolt mains), a poor oiling system, and uses different heads for 2V & 4V versions. The heads make all the difference and these fire breathing babies make this motor the legend it is. On the 4V, the valves are HUGE, measuring 2.19" intake and 1.7n" exhaust (don't remember exactly). Valves this large are only possible via a canted valve arrangement, forming what Ford refers to as a "poly-angle" combustion chamber. The valve covers are not straight - the front is flat and parallel to the ground, but a curve twists the rear parallel to the head. They are attached by 8-bolts and when removed, there is a 4 cast into the corner of the 4V and a 2 cast into the corner of the 2V (at least in 1970). The canted valves are the dead giveaway.
Dette er vel i grove trekk riktig, men ventil størrelser varierer mellom forskjellige typer topper. Mener også at nye topper til 351 bruker små tennplugger.
Morten R. N.
97 Ford F250 4x4
 Innleggets emne: .
InnleggSkrevet: Søn 30. Apr 2006 12:26
Takk for hjelpen! :)
InnleggSkrevet: Tir 02. Mai 2006 00:09
All beskrivelse her av 351C motoren stemmer også på 351M og 400, bortset i fra merkene på toppene. M motorene har en M innstøpt der C motoren har 2 eller 4. M motoren har også ett ennet boltmønster til girkassa (samme som 460)
