Dato/klokkeslett: Søn 25. Okt 2026 08:51
InnleggSkrevet: Fre 18. Jan 2008 16:02
Registrert: Ons 09. Jan 2008 19:18
Som sagt hva er forskjellen SAE og BHP?
InnleggSkrevet: Søn 20. Jan 2008 18:05
Registrert: Søn 09. Sep 2007 18:05
Kan ikke gi deg noe eksakt svar, men du kan kanskje prøve å lese deg fram til det her :
http://en.wikipedia.org/wiki/Horsepower
Tror egentlig bare det er måten hestene blir målt på...
1969 Pontiac Tempest Custom S conv.
InnleggSkrevet: Tir 22. Jan 2008 23:18
Registrert: Tor 15. Mar 2007 00:41
Bosted: Våler i solør
SAE er det som er oppgitt fra fabrikk, BHP er Målt effekt
Chevrolet camaro Iroc-z 350 tpi
Vortech kompressor, intercooler, wilwood disc brakes ++++
InnleggSkrevet: Tir 22. Jan 2008 23:35
Bosted: Ved siden av naboen
Brake horsepower (bhp)
Brake horsepower (bhp) is the measure of an engine's horsepower without the loss in power caused by the gearbox, generator, differential, water pump, and other auxiliary components such as alternator, power steering, and AC compressor. Thus the prefix "brake" refers to where the power is measured: at the engine's output shaft, as on an engine dynamometer. The actual horsepower delivered to the driving wheels is less. An engine would have to be retested to obtain a rating in another system. The term "brake" refers to the original use of a band brake to measure torque during the test (which is multiplied by the engine RPM and a scaling constant to give horsepower).
hp (SAE)
In the United States the term "bhp" fell into disuse after the American Society of Automotive Engineers (SAE) recommended manufacturers use hp (SAE) to indicate the net power of the engine, given that particular car's complete engine installation. It measures engine power at the flywheel, not counting drivetrain losses.
Starting in 1971 automakers began to quote power in terms of SAE net horsepower (as defined by standard J1349). This reflected the rated power of the engine in as-installed trim, with all accessories and standard intake and exhaust systems. By 1972, US carmakers quoted power exclusively in SAE net hp. The change was meant to 'deflate' power ratings to assuage the auto insurance industry and environmental and safety lobbies, as well as to obfuscate the power losses caused by emissions-control equipment.
SAE net ratings, while more accurate than gross ratings, still represent the engine's power at the flywheel. Contrary to some reports, it does not measure power at the drive wheels.
Because SAE gross ratings were applied liberally, at best, there is no precise conversion from gross to net. Comparison of gross and net ratings for unchanged engines shows a variance of anywhere from 40 to 150 horsepower. The Chrysler 426 Hemi, for example, in 1971 carried a 425 hp gross rating and a net rating of 350 hp.[6]
'68 Cougar XR7
MyGallery
