Dato/klokkeslett: Fre 12. Jun 2026 00:44
 Innleggets emne: Plastigage
InnleggSkrevet: Tir 14. Feb 2012 11:56
Hvordan går dere frem når dere måler lagerklaringen på veiva? Smører dere oljefilm på flatene før dere måler eller tørker dere rent? Har målt på en chevrolet motor nå med ny veiv og lagre. Får litt over .003 med tørre lagre. Dette er jo litt i overkant etter min mening. Ser på nettet at noen måler med lagrene smurte, men fremgangsmåten som plastigage anbefaler er med tørr overflate. Hvordan gjør dere det??
67 mustang
79 mustang
 Innleggets emne: Re: Plastigage
InnleggSkrevet: Tir 14. Feb 2012 19:16
Dette har vært diskutert gang på gang. Klaring er klaring men for å sette punktum så sendte jeg mail til dem:
Dear Olav,
Many thanks for your enquiry.
Yes, both the journal and the shell should be lubricated. But with different lubricants.
We recommend the use of a mineral grease for the journal and a silicone grease, such as MS4, for the white metal shell. The reason is to ensure that when the shell is separated from the journal the ribbon of Plastigauge remains intact to give a clean profile for the gauge card. Should the Plastigauge split when the shell is separated from the journal it becomes more difficult to determine the clearance. It is still possible however. Look carefully at the journal and you will be able to see where the plastigauge had been before the shell was removed. There will be both a real and a virtual ribbon. Apply the gauge card to the sum of them!
If the readings show 0.003 thousands of an inch (0.003”) that is the clearance, as defined universally. Of course, if the journal floats exactly mid-way the clearance would 2 x 0.0015”. In use, the clearance rotates, taking lubricants with it. In most engines contact metal to metal is prevented only by the strength of a few molecules.
I hope the above assists. Should you require any further information or assistance please do not hesitate to contact us immediately.
Kind regards,
Sarah Harwood
Export Sales Manager
PLASTIGAUGE
InnleggSkrevet: Ons 15. Feb 2012 16:28
fint! men burde det ikke holde å smøre flatene med olja du skal bruke da for å få rett avlesning på klaringen?
67 mustang
79 mustang
InnleggSkrevet: Ons 15. Feb 2012 21:40
Har aldri brukt noe annet en olje. Funker fint det, har målt mange lager på den måten. Enten det er motorlager, generator eller glidelager for mellomaksler.
Olav
InnleggSkrevet: Ons 15. Feb 2012 23:39
flott! takker for svar
67 mustang
79 mustang
