Dato/klokkeslett: Ons 28. Okt 2026 12:28
 Innleggets emne: Pontiac Lemans 1980 301 V8
InnleggSkrevet: Tir 28. Jul 2009 13:14
Registrert: Tor 23. Jul 2009 12:41
Bosted: Buskerud
Starting a engine overhaul
pont.JPG [ 79.1 KiB | Vist 8646 ganger ]
eng.JPG [ 81.18 KiB | Vist 8646 ganger ]
eng2.JPG [ 67.99 KiB | Vist 8646 ganger ]
eng3.JPG [ 51.63 KiB | Vist 8646 ganger ]
1995 Chevrolet Suburban 5,7 whit flow-tech headers and cherry bomb glasspack
1980 Pontiac Lemans (sold)
1990 Chevrolet Astro 4,3 V6 (sold)
2000 Chrysler Stratus (gone)
InnleggSkrevet: Lør 01. Aug 2009 19:39
Samme var min 318.. Vannkanaler på venstre siden av motoren var tettet igjen av slagg.. Skal du fjerne smog pumpen?
InnleggSkrevet: Lør 01. Aug 2009 19:49
Bosted: Karmøy
Hei
Hadde vært lurt å heise ut blocka å kontrollert lagrer/veiv når du først plukker.
Hva var problemet før du begynte?
Firebird Formula 455 '73
Bronco '78 Triple black
Recaro Trans Am '82 m/355 TTI
Astro '90 lav og kort
InnleggSkrevet: Søn 02. Aug 2009 23:29
= My 318 was like that too.. All the water/cooling ports on the left side of the block were clogged up with crap. Are you keeping the smog pump?
InnleggSkrevet: Man 03. Aug 2009 18:08
Bosted: Buskerud
this was a problem whit oil rings engine was using oil but now is out it was on honning put new rings
but one question did some one know where i can buy tool to remove/insert a camshaft bearing in Norge for ok price ??
InnleggSkrevet: Man 03. Aug 2009 20:52
Bosted: Karmøy
You can ask Sarpsborg motor 69137300
InnleggSkrevet: Tir 04. Aug 2009 19:21
Bosted: Buskerud
some new photos
untitled74.JPG [ 61.02 KiB | Vist 8445 ganger ]
untitled85.JPG [ 62.77 KiB | Vist 8445 ganger ]
untitled47.JPG [ 46.42 KiB | Vist 8445 ganger ]
InnleggSkrevet: Tir 04. Aug 2009 21:33
Do you have dual exhaust all the way? never seen a crossover that close to the engine. If you do not, I`d strongly recommend that you remove that crap and run 2,5 dual or bigger all the way back. I did 2` on mine but wish I had gone with 2,5`..
InnleggSkrevet: Tir 04. Aug 2009 22:17
Bosted: Buskerud
this is a dual exhaust all the way but some one make this by him self and very badly some one weld extra pipe in to original crossover and make dual #-o
InnleggSkrevet: Tir 04. Aug 2009 23:23
Yeah I can tell. My stock exh looked like that.. I just bought 100s of different bends and routed it all the way.. btw where are you from since you speak english?
InnleggSkrevet: Ons 05. Aug 2009 20:11
Bosted: Buskerud
i am from polen and making American dreams in Norge :D
InnleggSkrevet: Ons 05. Aug 2009 23:29
good to have you here!
then maybe, you can help us find a good, cheap chromer in polen!
the prices in norge, are extremly high!
InnleggSkrevet: Tor 06. Aug 2009 12:23
haha good one!
InnleggSkrevet: Lør 08. Aug 2009 10:04
Bosted: Buskerud
hehe maby but i thing sending parts to Polen and chrome them this can be also expensive the thing what i know i cheap in polen this is interior work :wink:
InnleggSkrevet: Man 31. Aug 2009 20:19
Bosted: Buskerud
some new photos :roll:
olo.JPG [ 28.82 KiB | Vist 8255 ganger ]
untitled00.JPG [ 54.86 KiB | Vist 8255 ganger ]
untitled89.JPG [ 22.79 KiB | Vist 8255 ganger ]
untitledlo.JPG [ 53.06 KiB | Vist 8255 ganger ]
Filkommentar: A Small surprise under sikaflex
untitledonm.JPG [ 48.07 KiB | Vist 8255 ganger ]
Brukere som leser i dette forumet: Google [Bot] og 77 gjester
