Dato/klokkeslett: Ons 28. Okt 2026 20:26
Opprett et nytt emne Svar på emnet  [ 52 innlegg ]  Gå til side 1, 2, 3, 4  Neste
InnleggSkrevet: Tor 24. Jan 2013 17:27
Registrert: Tor 24. Jan 2013 17:16
Hei,
Jeg trenger tips og råd angående en bil fra USA.
Om det er mulig å få denne godkjent med Norske skilter, hva extra som skal til.
Har desverre ikke så mye info, men legger ved noen bilder.
Håper på svar!
Dette er min første amcar vet :)
Under the cowl hood is a freshly built 350ci 5.7L V8 it sounds amazing, very loud. It idles and runs excellent. I was told the motor has under 800 miles on it. The transmission is a tci turbo 400 and shifts great. The exhaust consists of long tube headers mated to a 3 inch manderal bent exhaust system. The interior is clean, it has alot of aftermarket parts, including a behind the seats roll cage, racing seats, quick shifter, racing harness and much more. The door panels, dash and carpet look like new. The interior does need some odds and ends but nothing major. The underside of the car looks great, it looks spotless, almost like the car was rarely driven. The suspension is all new, as are the wilwood disk brakes up front. The driveshaft is a lightweight unit that cost the previous owner $1100 which goes back to the 12 bolt moser rear end. He stated that this combination is good enough to handle 1500 horsepower. The wheels look like new as do the tires. This vehicle has thousands of dollers invested and is going to make some one a very happy owner.The only things i noticed that the vechile needs were the headlight covers, windshield wipers, door panel pull handles and new seat rails. If you purchase the seat rails i cant have them installed for free. The Camaro does come with a ton of extra parts, it comes with the original factory seats, extra set of new bumpers, center console, new front and rear seat upholstry and other misc stuff them we recieved with the car.
bak.jpg [ 234.3 KiB | Vist 6874 ganger ]
Hjul.jpg [ 214.96 KiB | Vist 6874 ganger ]
front.jpg [ 228.09 KiB | Vist 6874 ganger ]
inne2.jpg [ 202.55 KiB | Vist 6874 ganger ]
inne3.jpg [ 216.8 KiB | Vist 6874 ganger ]
Sist endret av Olepjilot den Tor 24. Jan 2013 17:37, endret 2 ganger.
InnleggSkrevet: Tor 24. Jan 2013 17:32
Registrert: Søn 14. Okt 2012 13:23
Ser ingen bilder jeg ;)
Prosjekt: 1979 Dodge stepside pickup http://www.amcarforum.no/phpBB2/viewtopic.php?f=3&t=21165
InnleggSkrevet: Tor 24. Jan 2013 17:34
Nå da?
InnleggSkrevet: Tor 24. Jan 2013 17:42
Hmmm.. .Den så jo lettere oppjazza ut den der...
Sportsratt, sportsstoler, 4/5-punktsbelter, innvendig bur og cowl scoop... Noe sier meg at det ikke sitter en std motor i den heller?? Alle slike ting er ting de kan henge seg opp i på importvisning.
Det positive er, at siden bilen er såpass gammel skal den vurderes utifra kjøretøyforskriften anno 1942, men jeg vet ikke om de ser lettere på slike ombygginger som er så uoriginalt...
InnleggSkrevet: Tor 24. Jan 2013 18:50
Den er vel litt oppjazza. Det er ikke standard motor,men heller ikke hinsides!
Ratt,stoler, seler og bur kan jo kastes ut!!
InnleggSkrevet: Tor 24. Jan 2013 20:01
Bosted: Selbu
Ratt, stoler og bur skal gå tgjennom, mulig du må ha E merkede 4 punktseler. Camaro ble jo levert med store motorer fra fabrikk, så en smallblock går nok greit igjennom. Ta en tlf til Amcar, du må ha regdata fra dem, og hør om de kan anbefale fe andre endringene. Pass på så den ikke bråker for mye.
InnleggSkrevet: Tor 24. Jan 2013 20:26
Amcar Norge?
Takk:)
InnleggSkrevet: Tor 24. Jan 2013 20:49
Er nok mulig å få regget med litt flaks men ikke ta for gitt at det går greit. Bakstillingen der er de heller ikke glad i. Jeg tror jeg ville styrt klar med mindre du er villig til å ta sjangsen og bruke mye tid på krangling.
InnleggSkrevet: Tor 24. Jan 2013 20:54
Du får normalt ikke godkjent innvendig bur og 4-pktsbelter i en veibil. Er det fordi den er før -71 du mener det bør gå?
InnleggSkrevet: Fre 25. Jan 2013 03:09
bur som ikke godkjennes er hel bur, regelverket sier vel ikke for mye om et halvbur som mest sannsynlig er skrudd fast i gulvet...
InnleggSkrevet: Fre 25. Jan 2013 09:48
Bosted: Selbu
viewtopic.php?f=28&t=7609
InnleggSkrevet: Fre 25. Jan 2013 09:52
Se der ja, tusen takk :) Har jo til og med vært og kommentert i den tråden ser jeg nå... :lol:
Sist endret av AW-100 den Fre 25. Jan 2013 09:54, endret 1 gang
InnleggSkrevet: Fre 25. Jan 2013 09:53
Bosted: Selbu
Hvilken bakstilling er det? hvis det er ladderbars så er det håpløst å få godkjent. 4 link går. Ble godkjent en 70 Camaro i Trondheim i fjor med Heidts bolt in 4 link. Bladfjær med traction bars/momentstag er ok.
Fy fy
lb.jpg [ 42.74 KiB | Vist 6741 ganger ]
InnleggSkrevet: Fre 25. Jan 2013 12:17
Og husk at den mangler viskere og vedder mye på at det ikke er varmeapparat heller. Relativt bagateller men likevel. Lettere å få godkjent bur før 71
InnleggSkrevet: Fre 25. Jan 2013 12:30
Kan nok la seg registreres etter litt jobb, men er litt lite bilder og opplysninger om hva som er på bilen.
Amcar norge er greit å bruke i forbindelse med dokumentasjon og godkjenning.
Hvordan er det med rust på bilen? funker bilen ellers til vei kjøring, eller er den rigga for drag, ser ut som den mangler taktrekk og egentlig mye annet som hører til en standar bil, masse ekstra knapper, tru hva dem er til ?
Laderbar fikk jeg godkjent i 2011, så varierer svært fra hvor og hvem du viser bilen til
