Dato/klokkeslett: Lør 22. Aug 2026 15:09
Opprett et nytt emne Svar på emnet  [ 1783 innlegg ]  Gå til side Forrige  1 ... 22, 23, 24, 25, 26, 27, 28 ... 119  Neste
InnleggSkrevet: Lør 23. Feb 2008 17:06
:) I forbindelse med arbeidet med bakplata , så lurte på å montere in ryggelys , har jo rygge lys i baklyktene , de er jo ikke større en et stort frimerke :roll: må ha noen fine innbyggings lykter da , noen som har no forslag :?:
InnleggSkrevet: Lør 23. Feb 2008 19:41
camaro 69 hadde noe du kunne bruke. 4 kanta avlange som er frittstående. Mustangen 67 hadde runde lys.
InnleggSkrevet: Lør 23. Feb 2008 20:42
:) skal ta en titt på de camaro lysa Roar :)
 Innleggets emne: Panhard stag
InnleggSkrevet: Søn 24. Feb 2008 08:49
Litt tilbake til staget. Kom over en diskusjon....Det de sier er at om en bruker stag så bør/ må en bruke " kuleledd/ lager" i opphenget og ikje foringer. DA har det noe for seg!
Ref:
There is nothing inherently wrong with leaf springs. As a matter of fact, their design naturally resists rolling forces much better than a coil spring. Their biggest drawback in a competition environment is that they are heavy, and not easy to change rate on. However, I'd be willing to bet that a vast majority of coil over users on here do not use their car on a track often enough to really need to carry around springs that range in rate from 200 to 1000# in 50# increments, nor have the need to change wedge via spring height changes, so whats the point, really. Oh, well, they do look cool and are compact and light.
Yes, there is tremendous benefit to using a panhard bar on a leaf spring suspension, IF, you eliminate the potential for spring bind in the hangers so the springs can actually pivot and act solely as springs and not latral locators. If you use stock style bushings, poly, bronze, or aluminum, then you have the potential your leafs will bind up with a panhard bar. Use a leaf pivot and you can eliminate this potential bind. Once this is done, then the panhard can be used the same way as on a coil spring set up; to locate the roll center height and alter weight transfer characteristics.
Olav
InnleggSkrevet: Søn 24. Feb 2008 11:07
:) ja , det har kansje vert noe ja , takker :)
InnleggSkrevet: Søn 24. Feb 2008 17:56
såg litt på dem ja , vill sjekke hva hella har i sitt sortemang , trur e går for sjulte lykter , litt arbeid å lage til da , må sjekke om e har noen egna servoer ligende :-k
InnleggSkrevet: Søn 24. Feb 2008 19:51
Trenger en rygge lys a :?: Har fjerna de på flere biler jeg :lol:
InnleggSkrevet: Søn 24. Feb 2008 20:05
:) kjekt å ha når det e mørkt da
InnleggSkrevet: Søn 24. Feb 2008 20:39
:) I dag vart det ikke noe i garasjen med meg , e og e kompiss dro på garasje besøk i dag , litt greit å lufte trynet og ut å se hva andre holder på med også :wink:
InnleggSkrevet: Søn 24. Feb 2008 22:53
Neia blir da aldri mørkt her på berget :lol:
Synes den blir stiligere uten rygge lys i bak plata..
InnleggSkrevet: Søn 24. Feb 2008 23:03
:) Blir ikke visende disse da , først når du setter den revers det, deksel og servoer/motor og nå remeljer :wink:
InnleggSkrevet: Man 25. Feb 2008 00:19
Registrert: Tir 03. Jul 2007 19:15
Bosted: Kristiansund
send ut dama med mag-lite isteden... lite trua på denna ideen din :P
Don't mess with Texas! It's not nice to pick on retards!
www.NorthWestAmcar.com
InnleggSkrevet: Man 25. Feb 2008 00:23
:) pessimist :)
InnleggSkrevet: Man 25. Feb 2008 01:06
:) pessimist :)
du ingen nye bilder i dag?
InnleggSkrevet: Man 25. Feb 2008 01:14
thomas skrev:
:) pessimist :)
:) Har ikke vert i garasjen i dag , var på garasje besøk i dag , kjørte en tur innom moldestuket
