Dato/klokkeslett: Ons 28. Okt 2026 20:30
Opprett et nytt emne Svar på emnet  [ 114 innlegg ]  Gå til side Forrige  1, 2, 3, 4, 5, 6 ... 8  Neste
InnleggSkrevet: Lør 08. Jan 2011 21:10
Registrert: Man 10. Aug 2009 14:01
Bosted: Rett utenfor Oslo
Du har krav på svar etter forvaltningsloven. Har klaget inn trafikkstasjon tidligere når de "glemmer"å svare på spørsmål de ikke liker. :D
InnleggSkrevet: Søn 09. Jan 2011 00:02
Bosted: Sarp
Saksa ut fra en annen del i forumet her:
I følge eu direktiv E/ECE/324/E/ECE/TRANS/505 Kan parklys være orange foran, dersom de står i samme lygt som blinklys.
Her står det også at markeringslys kan være røde bak, dersom de er en del av baklys.
5.15. The colours of the light emitted by the lamps are the following:
main-beam headlamp: white
dipped-beam headlamp: white
front fog lamp: white or selective yellow
reversing lamp: white
direction-indicator lamp: amber
hazard warning signal: amber
stop lamp: red
rear registration plate lamp: white
front position lamp: white
rear position lamp: red
rear fog lamp: red
parking lamp: white in front, red at the rear, amber if reciprocally incorporated in the side direction-indicator lamps or in the side-marker lamps.
side-marker lamp: amber; however the rearmost side- marker lamp can be red if it is grouped or combined or reciprocally incorporatedwith the rear position lamp, the rear end-outline marker lamp, the rear fog lamp, the stop lamp or is grouped or has part of the light emitting surface in common with the rear retro-reflector.
end-outline marker lamp: white in front, red at the rear
daytime running lamp: white
rear retro-reflector,
non- triangular: red
triangular: red
front retro-reflector,
non- triangular: identical to incident light 4/
side retro-reflector,
non- triangular: amber; however the rearmost side retro-reflector can be red if it is grouped or has part of the light emitting surface in common with the rear position lamp, the rear end-outline marker lamp, the rear fog lamp, the stop-lamp or the red rearmost side-marker lamp.
cornering lamp: white
retro-reflective marking: white or yellow to the side;
red to the rear. 5/
InnleggSkrevet: Søn 09. Jan 2011 21:47
Bosted: Bærum
Terje Pedersen skrev:
Dominator skrev:
Iflg. EU-direktiv E/ECE/324/E/ECE/TRANS/505 kan parklys foran være gule så lenge de er kombinert med retningslys. Gjelder ikke dette EU-direktivet
*venter spent på svar* :mrgreen:
Har du en link til hvor dette står i direktivet? Googlet men finner ikke dette tema men derimot mye annet. Hold oss orientert om hva byråkratene svarer.
Det er riktig som Tomas van skriver over her, teksten er tatt fra denne tråden:
viewtopic.php?f=24&t=11061&hilit=ece+trans
Skal legge ut svaret fra Satans Vegvesen så snart jeg får det.
-88 Caprice Classic Brougham
-06 Dodge Durango 5.7l HEMI
InnleggSkrevet: Man 10. Jan 2011 09:04
Finner ikke noe EU regulativ som heter E/ECE/324/E/ECE/TRANS/505, men UNECE (United Nations Economic Commission Europe) har noen regulativer, deriblant dette. Finner ikke teksten som er nevnt ovenfor, men det er jo mye lesing her. Usikker på hvor mye dette er "regler" og ikke bare "retningslinjer" og dermed opp til hvert enkelt land hvor mye de vil følge det eller ikke...
http://www.unece.org/publications/trans ... icles.html
http://www.unece.org/trans/main/wp29/wp ... 1r4e_2.pdf - Add.1/Rev.4
http://www.unece.org/trans/main/wp29/wp ... 9r1e_2.pdf - Rev.1/Add.28/Rev.1
http://www.unece.org/trans/main/wp29/wp ... 018r3e.pdf - Rev.1/Add.17/Rev.3 11 July 2005
http://www.unece.org/trans/main/wp29/wp ... 05ep29.pdf - Rev.2 - 5 October 1995
http://www.safe-t-system.com/page5/assets/107.pdf - Rev.2/Add.106/Rev.1 8.october 2004
After Dark Van & Truck
Vårmønstringen i Haugesund
InnleggSkrevet: Ons 19. Jan 2011 15:36
Bosted: Bærum
Har pr nuh ikke fått svar fra Satans Uvesen, så purring er sendt til trafikkstasjonen [-o<
InnleggSkrevet: Lør 22. Jan 2011 17:52
Syns også Dominator's henvendelse til biltrangsynet var velskrevet og bra.
Ser for meg at mailen nå går varm rundt i mailboxene til de ansatte, ettersom ingen kan svare på spørsmålet hans..
Rent praktisk:
Når du ser en bil fra siden, og du ser kunn markeringslysene, er det da ikke mest hensiksmessig å se hva som er foran og bak på bilen?
Nå har vi en salig blanding av biler med orange/orange og rødt/orange. Det ser jeg som en kime til forvirring i trafikken.
En annen ting jeg har lagt merke til: Nye VW Passat har LED-baklys. Når de aktiverer blinklyset popper det plutselig opp som orange inni det røde. Litt stilig, men kan feilaktig bli tatt for å være bremselys.
Har lyst å sette inn LED bak på Camaro'en. Men da får jeg sikkert beskjed om at det IKKE er lov.. selv om nybiler er utstyrt med dette
InnleggSkrevet: Søn 23. Jan 2011 13:29
Registrert: Man 25. Jan 2010 20:05
Hadde litt problem med min 09 Challenger srt8.
Bla. at kjørelys var Oransje, men dette løste seg med og levere inn bilen på Dodge og få de til og aktivere DRL. i software
Noe som ikke er lovlig i Usa, men brukes i Canada.
Dette regner jeg med kan gjøres på de fleste nye biler.
Fikk også montert dobbelvirkende LED pærer bak, (hvit ved bremsing og Gul ved sidemarkering som blir oransje i rødt glass)
Alt dette fikset de på Dodge.
InnleggSkrevet: Søn 23. Jan 2011 16:47
Bosted: Hønefoss
Svaret lar vente på seg virker det som. Det er faktisk ganske så uholdbart, men signaliserer samtidig at man har truffet et sårt punkt.
InnleggSkrevet: Man 24. Jan 2011 16:28
Bosted: Bærum
Svaret er fortsatt fraværende ja. Bruker oftest å få svar etter 2-3 virkedager...
Ringte et verksted i dag og spurte hvordan de forholder seg til uoriginale lys. Gule parklys og røde markeringslys får du bare 1'er-feil på, så der slipper man billig unna. Røde blinklys bak derimot gir 2'er-feil og niks godkjenning. Så enkleste og greieste vei til godkjenning går via gule campingvognlykter bak (festet med TAPE)
InnleggSkrevet: Tor 27. Jan 2011 15:08
Saksa fra svaret Dominator fikk:
- Kombinert røde bremse og blinklys er ikke tillatt. Du må ha oransje blinklys.
Gjelder dette kun biler før 1971?
Tror ikke jeg har sett 50-60-tallere (Amcars) med orange blinklys her i landet.
Og noen har jo bare ei rød lampe bak, f.eks 1956 Chevrolet.
PS: syns å huske at fattern's SAAB V-fyra" fra 68 hadde hvite blinklys framme.
InnleggSkrevet: Tor 27. Jan 2011 15:47
Registrert: Ons 17. Sep 2008 21:54
Bosted: Stord
innteresant lesning dette her, jeg har `76 mod brukimportert amcar som er vist og godkjent hos biltilsynet med røde baklykter/blinklys, gikk greit men park lys foran som var gule måtte erstattes med nye kvite lys i grillen. skulle min egentli ikkje blitt godkjent pga baklyktene?
nej men titta, den brummar ju också
InnleggSkrevet: Tor 27. Jan 2011 15:53
Det skulle nok vært oransje blinklys bak, ja
InnleggSkrevet: Tor 27. Jan 2011 19:36
Baklysa dine er korrekt godkjent, for du har sikkert tatt den inn som verneverdig( da er kravet original og den kan godkjenes etter 42 reglene bortsett fra sidemarkeringslys som de ikke følger eldre regler på) og da er det lov med røde bak/blinklys. Men hadde bilen din blitt godkjent etter reglene som kom i 72 så hadde det ikke vært lovlig.
InnleggSkrevet: Tor 27. Jan 2011 22:23
Bosted: Bærum
Dette hørtes merkelig ut. Jeg har ringt til to forskjellige verksteder og fått samme svar ang. gule parklys foran. På EU-kontrollen vil du få en 1'er-feil pga. feil farge, altså er ikke dette til hinder for at bilen blir godkjent.
InnleggSkrevet: Tor 27. Jan 2011 22:38
Ved førstegangsvisning I norge skal alt være iorden også enerfeil.
Er noe annet på senere EU kontroller, men du er kanskje også klar over at hvis du fikk enerfeil på en visning og du får samme feilen på neste eu kontroll så skal det vel bli en toerfeil.
