Dato/klokkeslett: Fre 23. Okt 2026 13:42
InnleggSkrevet: Tor 26. Feb 2009 20:49
Registrert: Man 04. Feb 2008 23:36
Hei. Har et spørsmål her.. Passer fronten fra 69 camaro rs, rs/ss på 67 camaro? Med front så mener jeg da grillen og lyktedekslene.
Fant et kit her. Passer dette til 67?
http://www.firewheelclassics.com/store/item.asp?Category=15&SubCategoryID=148&GroupID=&SKU=RS69KIT
InnleggSkrevet: Tor 26. Feb 2009 21:53
Bosted: Lunde, Telemark
Hei, er ikke sikker, men jeg tror ikke det passer, mener å huske at skjermene ikke er like foran. Men du får jo komplett RS front fra classic industries til -67 mod.. eller ville du hatt -69 grillen?
67 RS CONVERSION KIT
1968 RS Conversion Kit: You've got a standard Camaro front end and you want to add a Rally Sport hidden headlight package. What do you do? In the past, some of the components may not have been available for this conversion. But now, Classic Industriesoffers exactly what you need to convert your standard front end to a Rally Sport front end! Yes, all the components you need are here! We now offer kits for 1967 through 1969, and at a discounted price! Save 10% on all components listed when purchasinga complete package. These conversion kits include virtually everything you'll need to convert your standard Camaro front end to a Rally Sport front end. Not only will you change the appearance, the headlight doors will be functional with all systems operating correctly once installed. The items listed below are what you will need to completely replace your front end and make it work! Most items in this kit are not assembled. As an added bonus when purchasing a kit, a Factory Assembly Manual for yourspecific year will be included at no additional cost. This comprehensive manual includes the most intricate exploded views of the entire vehicle including the Rally Sport headlights. The information will be valuable when assembling and installing the Rally Sport Front End Kit. All the items listed below are included in the kit. What's more, save an additional 10% when purchasing any of our Rally Sport conversion Kits! Note: This kit is not eligible for the volume discount offer. Items in this kitare not assembled with the exception of the RS headlight door section. The RS headlight door assembly is assembled and includes the headlight housing, headlamp hinge, outer black door, support bracket, bellcrank mounting plate, headlamp backing plate, bushings, headlamp adjustment screws, and the beam adjusting spring. These items are listed below under the pre-assembled category for your convenience. All other items will require assembly as indicated. For total authenticity, the lower front valancepanel should be replaced. The RS valance panel includes provisions for the park lamps which are located in the valance panel instead of the grill. Note: The standard fenders require adapter brackets for installation of the Rally Sport front end kit.The fender adapter brackets are included. Fender replacement is not necessary when installing the brackets. Assembly required 1 67 RS grill 1 67 RS lower grill molding 1 67 RS upper grill molding 1 67 grill assembly hardware kit 2 67 RS headlight bezel RH/LH 1 67 headlight molding nuts 6 67 headlight hinge bolts 1 67 headlamp nut and washer 2 67 fender adapter tab brackets RH/LH 2 67 headlamp motor w/housings RH/LH 3 67 headlamp relays 1 67 relay mounting bracket 4 67 headlamp limitswitch (4) 1 67 limit switch brackets 1 67 limit switch hardware kit Pre-assembled 2 67 headlight door assembly RH/LH 2 67 RS headlamp housing RH/LH 2 67 headlamp cover door RH/LH 2 67 headlamp cover molding RH/LH 2 67 headlamp hinge (pr) 2 67 headlampdoor plate RH/LH 2 67 headlamp output arm (2) 1 67 headlamp bushing kit
The item listed below is temporarily out of stock.
Please allow ample time for delivery.
$969.99 kit
http://www.classicindustries.com
InnleggSkrevet: Fre 27. Feb 2009 22:30
takk for svar. det er helst lyktedekslende med riller fra 69 rs som jeg synes er tøffere en på 67-68 rs. Men 69 rs grillen er noe tøffere den også enn 67-68 synes jeg.
