Dato/klokkeslett: Lør 24. Okt 2026 18:00
InnleggSkrevet: Man 27. Sep 2010 12:55
Registrert: Man 19. Jul 2010 14:29
Bosted: Norway
I made this list many years ago when I was restoring my 1969 Camaro, I used to work for the GM dealer back in the days
This is put here for your knowledge - all original parnumbers (may have changed over the years).
Moog parts where used since they uphold the GM quality and the price was just half of GM price.
understell / orginal GM partnumbers / AC Delco / Moog.
Pnr Desc
GM483275 --(bushing)
GM499473 -- (bushing)
GM390052 -- Mount (under the spring)
AC-S 5 -- Outer wheel bearing (front wheel)
AC-S 6 -- Inner wheel bearing (front wheel)
AC-290-79 -- Seal (wheel bearing front)
GM3893159 -- Body mount (Qty 2)
GM3914802 -- Body mount Qty (4)
GM14008366 -- Body mount Qty (2)
GM3901361 -- Body mount Qty (2)
GM3928380 -- Body mount (Qty 2)
Moog K 5103 -- Ball joint lower (Qty 2)
Moog K 5108 -- Ball joint upper (Qty 2)
Moog K 6076 -- Bushing for lower Control arm (Qty 4)
Moog K 305 -- Bushing for upper Control arm (Qty 4)
Moog K 74 -- Sway Bar Frame Bushing kit (Qty 2)
Moog K 5227 -- Sway Bar Frame Bushing (middle) (Qty 2)
Moog K 6099 -- Idler arm
Moog ES 381RL -- Tie rod end outer
Moog ES 3505 -- link (between tie rod ends)(Qty 2)
Moog ES 381N -- Tie rod end inner
Missing from this list are wheel bearings for the back axel - that varies with different types (10 bolt (7,5" - 8,5"), 12 bolt ... )
Going backwards
